Hello Nazreen,
You can use the
SHC68-68-EPM 68 Pin Shielded Cable (part #: 192061-01) to connect your PCI 6220 to the CB-68LPR.
The CB-68LPR connector block has 68 pins labelled "J0" through
"J67". These pins have a one-to-one correspondance with the 68
pins of your PCI 6220, i.e. pin "J5" of the
CB-68LPR correspondes to pin 5 of the PCI 6220. From looking at the M-Series Help
manual under 'IO Connectors and Pinouts'', you can find what pins
correspond to what actual signals on your DAQ device. The PCI
6220 has three ports (groups of 8 lines) available for digital
I/O. I can see from the pinout diagram for the 6220, that port 0
line 0 (P0.0) corresponds to pin 52, or terminal "J52" on the
CB-68LPR. I hope this helps!
Travis G.
Applications Engineering
Message Edited by Travis G. on 04-05-2006 04:54 PM
