04-08-2019 04:59 PM
Hi all,
I am currently trying to create a vb program to create a task to read a 0-5V TTL signal from my sensor and read the frequency of the signal continuously. The frequency will be dynamic so I cant just use the ctr0 to count on edge (0-250Hz max). I have tried using the examples given although they do not return any measurements.
How should I wire this? Could somebody give me a rundown on the visual basic examples such as the LowFrequencyCtr or the one for period measurement because im not entirely sure how they work. The Countdigitalevents example was easy to understand becuase it only required a looptimer although the more complicated ones use callback functions which confuse me.
Thank you.
Tom.
04-09-2019
05:51 AM
- last edited on
11-03-2025
03:28 PM
by
Content Cleaner
Hi Tom,
What examples are you referring to here?
If you are talking about how you should wire the PCI-6221, I would recommend having a look at:
- https://www.ni.com/docs/en-US/bundle/pci-pxi-usb-6221-specs/page/specs.html
Kind regards,
Michael
04-11-2019 08:07 AM
The Count Digital Events VB example lets me count on every edge without fail, although I cannot calculate the frequency here because the frequency will be changing.
My project is basically using my sensor to detect a ttl signal created by a rotating motor shaft, and I want to chart the frequency in my VB program. The example above cannot measure a dynamic frequency so I should be using the 'Measure Pulse Width' (i think) to measure the pulse widths and then calculate the frequency.
After that I need to create some sort of a feedback loop to sense the motor torque being upset, and then for the program to bump up the voltage to correct it, but ill try get the frequency charted first of course.
Sorry the last message was not clear. Must I wire an external gate frequency into the ctr0 gate pin to measure the widths? Or is this the correct way to go about this.
Thanks for the reply
Tom
