Counter/Timer
PCI 6602 to control 4 stepper motors on a mechanised microscope.
Hi Anthony,
Do you need to manually adjust the stepper motor from a knob in LabVIEW?  The previous example was a hardware-timed solution so you could have specific control over the rate.  If the exact rate of the motor is not important, you could try out this example that I put together:
Using SW-Timed Digital I/O to Control a Stepper Motor with DAQmx
"The other John P"
John Passiak
Message 11 of 11
(1,074 Views)
