Counter/Timer
PXI-6602 Clock (PXI and cPCI)
Why does the calibration procedure for the PXI-6602 instruct to use a PCI slot?  The PXI-6602 that I have has an EMPTY 10 MHz Osc silkscreened slot with several places for parts around it that have no parts installed.  Does it even have an onboard oscillator that will work without connecting it to a PXI chassis?  Where can I get a short cPCI to cPCI extender (that I can use in my PXI chassis)?
Thanks.
(1,572 Views)
Ok, the PXI-6602 has a specification if used in a PXI slot and another spec if used in a cPCI slot.  How can I get a Hybrid PXI extender without the PXI connection?
Thanks.
(1,518 Views)
