Counter/Timer
PXI 6608
Hello guys,
i'm working on project using PXI 6608 as counter that count event. I'm using CVI  to run this device , but when I run the program it gave me nothing to count even though I have created the device in NI MAX .
My second is , are all the PXI'S working in CVI as well as in LABVIEW  ?
THANK YOU.
(2,087 Views)
LabVIEW is *not* required, CVI should work just fine.  Post your code and maybe someone can help find the problem.  (Likely not me though, as I only program data acq in LabVIEW.)
-Kevin P
(2,018 Views)
Hi Kevin P,
Actually Am using the code of NI I mean the example . But when run it gave nothing.
(2,011 Views)
