Counter/Timer
Problem with gating on a Edge Counter with NI-Daqmx 8.0
I am using LabView 7.1 with NI-Daqmx 8.0.  My data acquisition card is a NI-DAQPad 6016.  I want my signal source (CTR 0 Source pin 50)  to be edge counted when my gate is high (CTR 0 Gate pin 52).  Basically, I would like my signal source and my gate to act like a AND Gate.  Is that possible...?  The gate does not work and I cannot find  the right function for it.  In the NI-Daq traditionnal I was able to choose my gate has an input to my counter function. It does not seems to be case for NI-Daqmx... He is my code.
Thank you very much,
I appreciate it a lot,
Philippe
(3,815 Views)
In DAQmx, setting up the GATE for single point edge counting is done using the pause trigger attributes.  There is a LabVIEW example that ships with DAQmx called "Count Digital Events-Pause Trig.vi" that should take care of your needs.
gus....
(3,627 Views)
Thank you very much, it should work well.  I appreciate it !
Have a great day,
Phil
(3,621 Views)
