Counter/Timer
Problem with "Means Two Edge Separation.vi"
Hi, good morning, I have a problem and I wonder someone can help me.
Currently, I'm developing an application with a NI DAQ (model USB6251), which use an VI example of Labview called: "Means Two Edge Separation.vi". One characteristic of this VI is that you can begin or stop a count by the rising or falling edge of a digital input. However, when I run this VI it doesn't work correctly because it only works when I use the rising edge as the beginning of the count and the falling edge as the end. If this example can work properly with the NI DAQ model I'm using my question is, what I am doing wrong or is this VI badly programmed?
Thank you.
Message 1 of 1
(3,498 Views)
