Counter/Timer
ticks
If I put a "wait" command in an FPGA VI, how do I find out how long a single "tick" is?
Craig.
(4,199 Views)
I've only just looked at labview fpga, but one tick is one clock pulse. The wait also has micro seconds and mili seconds which may be easier to read the code. Depending on your device, compact rio etc.. there should be timing specs on NI's website that should let you know what one tick is. Like 50MHz is 50,000,000 ticks a second. 🙂 Hope this helps you.
Message Edited by pRoFiT on 07-23-2008 02:30 AM
- A minute saved is a Minute earned!
(4,187 Views)
I see - that makes sense actually. Thanks.
(4,180 Views)
