Counter/Timer
Pulse Measurement with PXI-6624
My PXI-6624 works with PXIe-8135. I want to measure a PWM both frequency and duty cycle. I set up the select measurement type is "Pulse Measurement" in System Explorer. Once I deploy it, I got an error code " -200431":
"Selected physical channel does not support the measurement type required by the virtual channel you are creating."
"Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type."
Can this card work in "Pulse Measurement" type? How can I test both frequency and duty cycle of a PWM? Is there some add-on custom device that I can download and use?
(5,416 Views)
Hi Caonan,
It looks like a similar questions was answered on another forum post here (http://forums.ni.com/t5/Counter-Timer/PXI-6624-Pulse-Frequency-measurement/m-p/2277488#M11024). Have you looked at that post?
Jake H
(5,375 Views)
Yes, I read it. But I cannot understand what I should do. I know the concept of measurement of pulse width. I also know what I should do, if there is a PCI-6624 works in Windows OS. But I don't know about remote system.  Is there some custom device I can use?
(5,356 Views)
Hi Caonan,
Are you working with a PXI chassis? Are you trying to measure the duty cycle and frequency on what channel (digital input, digital output, couter input, counter output)? Could you provide a code snippet?
Jake H
(5,337 Views)
