Counter/Timer
while loop inside control & simulation loop
Hi all,
I have a problem when using while loop inside mathscipt used inside control & simulation loop.
I want to read a excel cell each 5 seconds and to do it I'm using matlab scrip to know when I have to change cell.
My inputs on mathscipt are: run_time and sim_time. 1st one is the running time from control & simulation loop and 2nd is the time of each simulation.
My output is cell to go to the VI excel reader.
So, to do it I'm using a while loop like this:
cell=H1;                                       % starting on excel cell H1
count=1;                                       % creating and starting counter variable
h=5;                                               % creating and starting second counter
while run_time < sim_time do   % while loop: do it until reach simulation time.
if run_time ==h                             % compare running time with next 5 second (5,10,15,20,...)
count = count +1;                         % increase counter for next 5sec
h=h*count;                                     % to compare on "if" next loop (5+5, 10+5, 15+5,....)
cell=strcat('H',int2str(count));     % put on ouput next cell: H2,H3...
end
end
But, when I used while loop it doesn't do nothing. My code is working without while loop, but it only does 2 cells. I want more than that.
Is there anyone can help me with it? another way to do it?
Thanks in advance.
Regards.
Marco
(5,055 Views)
Hi MarcoAlmeida,
Did you try step by step debugging ?
If yes, what happen inside your while loop ?
Regards
(5,014 Views)
Hello ThibaultP,
No I didnt try. I'll do it and come back to say what happen.
Thanks.
(4,990 Views)
Hi again.
I tried to do it but it seems to be dificult to me to understand what is going on inside loop because Vi is too big with multiples sub-vi's.
I got another way to do what I want.
Thanks anyway.
I have another problem reading excel files: my simulation gets too low but I'll try to do a search for same problem in another topic.
Regards
Marco
(4,941 Views)
