Counter/Timer
RPM measure
Hi i have to measure the RPM of a DC fan using a optical sensor that generates a 0-5V... Can anybody give me a hand? I use a NI 9401
Thanks Pollon
pollon
(5,081 Views)
Are you using this module on a cDAQ chassis or a CRIO?
(5,074 Views)
On a cdaq
pollon
(5,056 Views)
Hi i'm trying to read with signal express a 5V ttl signal generated by a function generator, but what i see on the screen is very disturbed signal. Could you please tell me why?
pollon
(5,053 Views)
Hello Pollon,
since you're using a Compact DAQ chassis, you can put the NI 9401 module in either slot 5 or 6 of the chassis 9172 to use one of the two counters.
You can do then a simple counter frequency measurement to get the frequency of the TTL signal.
Take a look at this link to learn more about frequency measurements with cDAQ:
Frequency Measurements: How-To Guide
Hope this can help.
Andrea N.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(5,051 Views)
