Counter/Timer
Reading in multiple pulse inputs with NI DAQmx in Python
Hi everyone,
I am trying to read in multiple pulse inputs simultaneously using the nidaqmx library in Python, and I'm having some trouble. My physical setup consists of the following:
DAQ: NI-cDAQ-9178
Module: NI-9411 (Digital Input)
I know there isn't a lot of great documentation for using the nidaqmx library with python but I don't believe I'm attempting anything too complicated and I'm hopeful that someone can identify the error in my ways. For context, I'm essentially trying to use the NI-9411 as a counter for continuous edge detection. I've been able to successfully create a task that reads in pulses from an external signal generator. The problem however comes when I try to create multiple tasks (i.e. read from multiple channels). I have attempted to configure a separate task for each of the four channels and have used the add_ci_count_edges_chan() method to configure each task for edge counting. I am then attempting to continuously read the counts from each channel in a loop using the ci_count property. The result is that Channels 1 and 2 seem to work fine and read their corresponding pulses, however 3, and 4 just seem to be duplicating the read from channel 2. Here is an example of my code:
import nidaqmx
import nidaqmx.system
from nidaqmx.constants import Edge
import time
system = nidaqmx.system.System.local()
# ci Channel names where system.devices[2] = cDAQ1Mod2
cDaq = system.devices[2].name
ci_chan1 = system.devices[2].ci_physical_chans[0].name
ci_chan2 = system.devices[2].ci_physical_chans[1].name
ci_chan3 = system.devices[2].ci_physical_chans[2].name
ci_chan4 = system.devices[2].ci_physical_chans[3].name
# Define the input channels and tasks
task1 = nidaqmx.Task("task1")
# Configure the task for edge counting
task1.ci_channels.add_ci_count_edges_chan(counter=ci_chan1,
name_to_assign_to_channel="",
edge=nidaqmx.constants.Edge.RISING,
initial_count=0)
task2 = nidaqmx.Task("task2")
task2.ci_channels.add_ci_count_edges_chan(counter=ci_chan2,
initial_count=0)
task3 = nidaqmx.Task("task3")
task3.ci_channels.add_ci_count_edges_chan(counter=ci_chan3,
initial_count=0)
task4 = nidaqmx.Task("task4")
task4.ci_channels.add_ci_count_edges_chan(counter=ci_chan4,
initial_count=0)
# Start the task
task1.start()
task2.start()
task3.start()
task4.start()
try:
while True:
count1 = task1.ci_channels[0].ci_count
count2 = task2.ci_channels[0].ci_count
count3 = task3.ci_channels[0].ci_count
count4 = task4.ci_channels[0].ci_count
print("Count 1: {}, Count 2: {}, Count 3: {}, Count 4: {}".format(count1, count2, count3, count4))
time.sleep(1)
except KeyboardInterrupt:
pass
finally:
# Stop and clear the tasks
task1.stop()
task1.close()
task2.stop()
task2.close()
task3.stop()
task3.close()
task4.stop()
task4.close()
Any help or advice would be greatly appreciated. Thanks in advance!
(2,968 Views)
Accepted by topic author Hedrick
It turns out my problem was not with the code but instead my physical setup. I failed to use pull-up/pull-down resistors for my setup and therefore my readings were getting synced to different channels. I don't have a great background in electronics so I apologize if I don't get the technical explanation exactly correct. If I had read the specifications for the 9411, I would've realized that this module doesn't have channel-channel isolation. Regardless, I hope this post can be used as a basic template for reading in multiple pulse signals using daqmx and python.
(2,930 Views)
