Counter/Timer
Route multiple 6602 counter inputs to one counter output...
Hi!
I´d like to route 4 different ttl signals, that are read by 4 different counter inputs to one single output channel (e.g. the output of one of the counters used) using pulse train generation with a divider of 4. Note that only one of the four inputs is active at the same time, to prevent overlay.
How can I do that with Traditional-DAQ?
Setup would look like this on the SCB-68
TTL1 ----o in0 (ct0)----o out0 TTL(1..4)/4 [Hz]
TTL2 ----o in1 -- (output of ct2 is redirected ro ct1)
TTL3 ----o in2 --
TTL4 ----o in3 (ct3)--
May it be better to just output each counter input signal at it´s own output and connect these outputs to one free I/O-pin hardwired?
Best regards
Zorniki
Message 1 of 1
(3,176 Views)
