 ajx
			ajx
			08-31-2005 12:35 PM
09-01-2005 08:08 PM
 fredni
			fredni
			07-20-2006 03:41 AM
 fredni
			fredni
			07-20-2006 03:43 AM
07-21-2006 02:55 PM - edited 07-21-2006 02:55 PM
Message Edited by McKala[DE] on 07-21-2006 02:58 PM
 fredni
			fredni
			07-24-2006 02:09 PM
 stilly32
			stilly32
			07-25-2006 04:46 PM
Hey Fredni,
In response to "ticks" not being available, it looks like you may have selected a the CI.Frequency.Units property instead of the CI.Period.Units. Ticks should be available if you change to that property.
Also for signal routing, a good resource is Device Routes in MAX - just select the device and select the tab at the bottom of the window. It will show you that unfortunately, the output from counter 2 (PFI 28) cannot be internally routed to the gate of counter 0 (PFI38).
Hope this helps,
Andrew
 fredni
			fredni
			07-26-2006 10:19 AM
 fredni
			fredni
			07-27-2006 04:01 AM
 fredni
			fredni
			07-27-2006 04:43 AM
