Counter/Timer
Toggling pulseline based on timer
Hi:
I am using Counter 0 to make a pulse. The output comes to CTR 0 OUT. How do I send the output to DIO/0?
Thanks, Sam
(3,412 Views)
Two words: wire, screwdriver.
(There isn't a software method available to do this.)
-Kevin
(3,412 Views)
Hello Sam,
It is not possible to route internal signals to DIO lines. However, it is possible to route your CTR0 OUT signal to another PFI line. I am not sure if this will be to helpful for your application, but it would give your another connection point from which to access the signal.
Let me know if you have any additional questions on this issue.
Bill B.
(3,412 Views)
