Counter/Timer
Trigger analog acquistion with an encoder
I'm using an encoder that gives 1800 pulses per revolution and a would like to logg my analog signals at every encoderpulse? Has anyone a solution to this?
/Sasa
(3,315 Views)
You don't say what hardware you have but in principle look at the 'Acquire N Scans Digital Trigger VI' and connect the encoder to the RTSI line.
The rate of 1800 pulses per revolution could be good fun though depending on the rotational rate.
(3,263 Views)
