      We are trying to measure position with 6601. The frequency of quadrature encoder is from 100Hz to 8MHz. Now, we connet the A,B and Z channel directly to counter . Using the example in CVI, we change the filter to 100ns and use x4 mode. It works perfect at low frequency.
      The problem is when the frequency of encoder is higher than 2MHz, the accuracy decreases greatly. I'd like to know about following:
1.Can 6601 do the previous task enough? Or I must change to use 6602.
2.If 6601 is available, is there any way to increase measurement accuracy ?(in software or wire connection )
