Hi Matthieu
I am still experimenting with different operation modes of my two counters on the 6025E-Board.
Every time I try to use
both counters and at least
one of those in the "finite samples" mode, I get the error message attached to the last posting. Thus I still assume that there are simply
two counters needed to produce a finite number of pulses
even if I only use one explicitly in my code: The first to count the clock cycles in order to produce the desired frequency and the other to count the pulses produced by the first one.
So I simply do not have enough counters to produce two series of finite samples (according to my reasoning there would be 4 needed).
Please let me know, if my speculation is right.
