Counter/Timer
best card for 1 -100 hz pulse output with variable duty cycle
What would be the best card to output 1 -100 Hz pulse with variable duty cycle with maybe 4-8 digital outputs.
It would be very preferable to be a USB compatible card and be cheap.
Also, I am not very fimiliar with LabView.
Will I  be able to program to card easily with the Basic version?
Thanks for any suggestions.
(4,234 Views)
Hello JPNaidu,
I would suggest using the USB-6210 or the PCI-6602.  You would only need 1 counter per PWM signal.  The USB-6211 only has 2 counters so you might need multiple boards.  The PCI-6602 has 8 counters but uses the PCI bus architecture.
Here is a great DevZone article that describes how to setup a PWM signal in LabVIEW.  Refer to Figure 3 in the article.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(4,221 Views)
"Here is a great DevZone article that describes how to setup a PWM signal in LabVIEW.  Refer to Figure 3 in the article."
Its great when using counters, not so great when using DIO.
1-100Hz PWM over USB on 8+ digital lines should be a simple task for LabVIEW but I haven't found a single example of this anywhere
(3,993 Views)
