Counter/Timer
Adding time/duration-stamp at instants to a textfile
Hi.
I've got some help from Jared to set up a measure envirment where I can store state changes to a textfile. What I would like to add now is a time column which shows the elapsed time in millis or rather micros.  It is only at the the instants when a state, for example 0 0 1 is written to file I would like to know the elapsed time.
I would like it like:
time (us) | di1 | di2 | di3
1                 1      0      0
7                 0      1      0
I've tried to set up such environment, but not successed. It shouldn't be hard and I've been trying the timing functions without luck 😞
I would be grateful for all hints and help.
A example of output textfile can be found here: http://bachman.tor.lindesign.se/tmp/minfil5.txt , workspace, screenshot are attached,
thanks /Bachman
Message 1 of 1
(3,385 Views)
