Counter/Timer
period measurement trigger rearm
Hello I want to measure pulse widths (8 channels on a 6602) triggered by a PFI (PFI0, f.i.). The trigger comes from my LabVIEW-application in user-definable intervals of about 1 - 5 secs. The examples provided with LV show taking a finite number of samples without a loop. But I cannot tell in advance how many samples I'll need, and I'd like to see the results before all samples are taken. I can set a trigger property to arm the trigger. But I could not find a solution to re-arm it so as to employ it in a while-loop. Most applications that are discussed here deal with counter output. Which works. But not on pulse measurement input. Thank you for your help. Michael
(3,524 Views)
Hello nimic,
thank you for contacting National Instruments.
I think the example in the following link should help to solve your problem. "NI-DAQmx: Buffered Event Counting on all Counters of a 6602 or 6608"
http://zone.ni.com/devzone/cda/epd/p/id/4836
Please feel free to contact us again for further informations.
Best wishes, Jan Kniewasser
National Instruments Germany
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,421 Views)
