Counter/Timer
cablage compteur contact sec et module 9361
Bonjour,
Je souhaite compter les impulsions émises par un compteur électrique sur le module 9361.
Quel câblage dois-je réaliser ? Faut il une alimentation car le contact est sec
Cordialement
(1,504 Views)
Please refer to the user manual/getting started to understand the connections - https://www.ni.com/pdf/manuals/376285b.pdf
This is what Google translate gave me,
I want to count the pulses emitted by an electric meter on the 9361 module.
What wiring do I need to do? Is there a power supply because the contact is dry
I assume that your question is how to power your "dry contact" on some sensor used to detect the electric meter pulses.
You need to connect an external power supply and connect the device as shown.
Santhosh
Soliton Technologies
(1,499 Views)
