Counter/Timer
counter input property in the DAQmx Channel Node
I found  there is no counter input property in my DAQmx Channel Node as shown in the figure attached. How to set counter input channel node?
Thank you.
(1,419 Views)
Accepted by xi438172@ucf.edu
Right-click on the property node, click Select Filter...
Select first option and make sure you select a counter in the counter control wired to this task.
https://tmesystems.net/
(1,406 Views)
Got it! Thank you so much!
(1,094 Views)
