Counter/Timer
counter noise on cDaq9178
OK, John, I am getting closer. Thanks for the lead to the "this KB"   However, I am getting something that does not appear to match the content there.  See the attached screen shot where I am trying to create the property channel node. I can create it and select Period-DigitalFilter-Enable, but, the arrows that display are OUTPUT arrows, but, in the "this KB" (arrows right direction)  the arrows are input functions.  What am I missing here?
Should I be creating input or outputs on the property channel node?  The instructions  appear to show inputs, but, I cannot see how to configure them as inputs.
Dave
Message 11 of 13
(2,814 Views)
Hi Dave,
In LabVIEW, the arrows on the right indicate you are reading from the property, and arrows on the left indicate you are writing to the property.
Since you want to set the value of the property (rather than query the current values), you will need to change the property to Write.  You can do this through the right-click menu:
Best Regards,
John Passiak
Message 12 of 13
(2,804 Views)
That works! Thanks.
Message 13 of 13
(2,791 Views)
