Counter/Timer
counter triggering, synchronising period measurements etc...
I have a PCI6602 card which I want to use to measure instantaneous angular speed from 3 different sensors (a quadrature encoder, magnetic pickup+gear and optical sensor – with conditioning to give a TTL output). I think this means I need to connect each of the signals to the GATE on three of the counter channels, with the sources set as the internal time base, so that I can do continuous period measurements on all three channels.
My question is, is it possible to configure the counter to start timing simultaneously on all three channels upon receiving a reference signal, such as the “Z” signal from the encoder? If so, how do I do this and where should the reference signal be connected to?
Also, I have been trying to write a program in LABVIEW to acquire period measurements on three channels, but the DAQ assistant won’t let me have more than one channel in the task (when I run it, it says I need the multi channel version of DAQmx read but I cant find this). I could have 3 separate tasks to acquire each channel but I’m not sure if they would be synchronised if I did it that way? (I tried it with the execution highlight thingy on and it seemed to do one measurement after the other).
Thanks, 🐵
Tim
(4,017 Views)
That error message is a little misleading. You cannot have multiple input counters in a single task, so you will need to use a separate task for each counter. In order to synchronize measurements on the 6602, you should configure each counter to use an Arm Start Trigger. There is a duty cycle measurement example that uses the Arm Start Trigger that ships with NI-DAQ. For all three measurements, set the Arm Start Trigger Source to the same signal and you should be set.
I hope this helps!
gus....
(4,006 Views)
Thanks!
I've got 2 seperate period measurement tasks working properly now, I'll have a look for the duty cycle measurement example... any idea where you would normally connect the signal for the arm start trigger
on the timer board?
Tim
(3,996 Views)
There is no default for the Arm Start Trigger, so you can select any PFI line as the trigger source. Most every PFI line will have a direct connection to the arm start trigger.
I hope this helps!
gus....
(3,993 Views)
Thanks!
I had a look at the DAQmx duty cycle example today and it seemed to make sense!
Tim 🙂
(3,984 Views)
