Counter/Timer
counter update max frequency
Attach is my vi for updating of counter duty cycle. I want ot update faster than current speed around 500Hz. I am using NI 6070E.
Thanks.
When you feel sad, laugh
(4,110 Views)
Hi maymathur,
I modified your code slightly to make it more efficient. The Is Task Done VI was significantly slowing down the update rate. I removed it and now it works alot faster.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(4,097 Views)
Hi Abhinav,
Thanks for the answer. If I remove the "is task done" it can work much faster but what is the function of "is task done"? is it just qurey the status and why does it take so long to run?
Is there any difference "Is task done?" and "wait until finish?".
Thanks and with best regds,
maymaythar
(4,088 Views)
I recall reading about something similar here on the forums before.   Ah yes, here's a thread.  After reading through that thread, it still isn't clear to me why your call to "Is Task Done?" should cause such a slow down.  It sounded like the actual boolean "task done?" status might be stale by up to 100 msec, but the call to query that status should nevertheless return immediately.
-Kevin P.
(4,078 Views)
