Counter/Timer
Kind of PCI interface
Does the PCI-6602 board is compliant to PCI-2.2, 3.3 volts ?
Regards
Ben
(3,260 Views)
Hi Ben,
Any new PCI-6602 is compliant with the PCI 2.2 specification with a 3.3 volt bus.  If you have a older board, then I would want to check the serial number to make sure you had a more recent revision number.  All of the boards were re-designed to work the PCI 2.2 specification when it came out, but some older manufactured boards would not work with it. Please let me know if you need further help.
Thank you,
Michael D
Applications Engineering
(3,242 Views)
