Hi Mami.
The only other USB devices I have are mouse and a keyboard.
 Looks like it takes about 30 seconds for DAQ library funcrion call : DAQmxErrChk (DAQmxBaseCreateTask("port29",&taskHandle));
what kind of errors you are getting?
This is the recent test code:
It looks like once board is ready it works without delay...
Thanks a lot,
andrei
//************************cut below this line ***********
* ANSI C Example program:
*    melter.c
* Example Category:
*    CI
#include "NIDAQmxBase.h"
#include
#include
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
static int gRunning;
int main(int argc, char *argv[])
    // Task parameters
    int32       error = 0;
    TaskHandle  taskHandle = 0;
    char        errBuff[2048]={'\0'};
    time_t      startTime;
    // Channel parameters
    char        chan[] = "Dev1/ctr0";
    char        name[20];
    // Data read parameters
    uInt32      data=0;
    uInt32      startCounterValue = 0;
    float64     timeout = 0.0;
      printf("Initializing DAQ board\n");
     printf("Board is ready, Type S (start) and press enter key\n");
     scanf("%s",&name);
    DAQmxErrChk (DAQmxBaseCreateCICountEdgesChan(taskHandle,chan,"",DAQmx_Val_Falling,startCounterValue,DAQmx_Val_CountUp));
     printf("READY2\n");
    DAQmxErrChk (DAQmxBaseStartTask(taskHandle));
	gRunning = 1;
	// The loop will quit after 5 seconds
	//C function gets time
	startTime = time(NULL);
	int counter1 = 1;
 printf("READY\n");
	while(counter1 <= 100) {
        DAQmxErrChk (DAQmxBaseReadCounterScalarU32(taskHandle,timeout,&data,NULL));
		printf("Iteration: %d\n",counter1);
		printf("Count: %d\n",data);
		//printf("Time: %d\n",time());
		counter1++;
	 printf("Will run test for 10 seconds\n");
	// The loop will quit after 10 seconds
	while( gRunning && time(NULL)        DAQmxErrChk (DAQmxBaseReadCounterScalarU32(taskHandle,timeout,&data,NULL));
		printf("\rCount: %d",data);
	counter1 = 1;
		counter1++;
//*DAQmxErrChk (DAQmxBaseClearTask(taskHandle));*/
Error:
	puts("");
	if( DAQmxFailed(error) )
		DAQmxBaseGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
        DAQmxBaseStopTask(taskHandle);
        DAQmxBaseClearTask(taskHandle);
		printf("DAQmxBase Error: %s\n",errBuff);
	return 0;
