I have configured the 6601 to generate a 1khz train on Ctr0
I would like to feed this into the source of Ctr1 to generate pulses of longer duration.
I use the command DaqmxCreateCOPulseChanTicks to set up my pulse train on Ctr1.
It works if I leave the source terminal as Null "", but it does not work if I change the source.
To change the source, I have wired ctr0 output to the source of ctr1 and use the label "dev1/PFI39" as the source terminal and have tried "dev1/ctr0Output".
I am using Visual Basic 6.
What am I missing?
