Counter/Timer
how can i add an input to my front panel to edit my "threshold start level"
I have a vi using the trigger and gate vi and would like to edit the "threshold start level" from the front panel. What would be the procedure?
Thanks, HG
(5,356 Views)
Right click on the express VI and select Open Front Panel. This will convert it to a regular VI. Add the control to the connector pane. The level is part of a cluster so you can have the whole cluster as a control or have a control for just threshold and add it's value to the other elements with the Bundle by Name function.
(5,353 Views)
Thanks for the help Dennis.
HG
(5,326 Views)
