Counter/Timer
how many different kinds of devices can be connected to modbus protocol?
My question is we have a maximum of 247 slave IDs .
Each Device has some unique slave Id .
In this way  can we connect only 247 different types of devices to the modbus . ?
Can i have some clear explaination please?
(8,785 Views)
Accepted by mahi108
Modbus is restricted to addressing 247 devices on one data link, which limits the number of field devices that may be connected to a master station.
However, if you want to increase the number of slaves, you may use MODBUS/TCP.
Here is a link that might help you:
http://modbus.control.com/thread/1026247380.
The Schneider electric 174CEV30010 Modbus to Ethernet bridge is capable of addressing Modbus slaves from 1 to 247.
The actual number of devices which can be physically connected depends on the medium used and not on the fact it is Modbus.
Some examples:
RS232 is a 2 device point to point connection when using copper, however when using fiber (or other modems) it is possible to connect up to the maximum of 247 devices.
RS485 is multi-drop and supports 32 devices on a single network. When a repeater is used, on copper wire, the number of devices can usually be increased to 64.
Hope this helps.
Rohan Sood
Applications Engineer
(8,687 Views)
