Counter/Timer
how to measure frequencies of two sources simultaneously using 6602?
I am using pci-6602 & LabView to measure frequencies of two sources. I wired Measure Frequency (NI-TIO).vi to do it, but it seems the counter only works at one channel at a time. Can anybody send me an example vi?
Many thanks in advance
ZYuan
(3,228 Views)
Hi ZYuan,
To measure the frequencies simultaneously, you would need to duplicate the code for the single counter example twice and link the error cluster from one set to the next. I don't have a specific example but the following example can be used as a guide.
Simultaneous Buffered-Event Counting on All Eight Counters of the 6602 or 6608 Devices
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DC9F56A4E034080020E74861&p_node=DZ52325&p_source=External
Hope that helps. Have a good day.
Ron
(3,228 Views)
