Counter/Timer
how to run servo motor reverse direction?
hello
I am running a servo motor  with counter vi and NI DAQpad-6015. it is rotating from 0° to 90° .but i dont know  how can i rotate the motor reverse direction. I mean 90° to 0°.
regards
shafiq
(6,412 Views)
Is there a direction input available on the driver unit for your dervo motor?
Mainstream servo drives control direct and torque (or velocity) via a +/-10V control signal. Positive voltages produce one direction of rotation, while negative voltages produce opposite direction of rotation.
Sounds like we need more details on you driver hardware
(6,409 Views)
I got theree cable from servo. one is for +5v, 2nd cable for ground and 3rd one is for Pulse.So I have connected all wire in the DAQ.  I n generating pulse and it is running one direction.
(6,400 Views)
Do you have literature for the servo? What does it say?
Manufacturer and model # would be useful, without any further info on your servo, I cannot suggest any thing.
(6,394 Views)
I got the solution.
(6,390 Views)
