Counter/Timer
interrupt PC-TIO-10 on Visual C++
I use Windows ME use NIDAQ Version 6.9.
I have card Timer card(PC-TIO-10) and Analog in/out card (AT-MIO-16E-1). If i want define sampling time 0.1 ms to PC-TIO-10 (Now i use IRQ 5 recieve interrupt from PC-TIO-10). I use Visual C++ V6.0 if has occur interrupt every 0.1ms my program read value analog from AT-MIO-16E-1 and show value on screen.
I read example form NIDAQ 6.9 now i don't understand. you have simple program for test interrupt ?
Can you send example program to me,sir.?
Best Regard.
Mr.Somphong Tanok
(3,915 Views)
Hello;
I'm attaching an example code that uses Daq Event 8 to send messages when a digital pattern is matched. You can refer to that example to see how messaging works with NI-DAQ.
Hope this helps.
Filipe
(3,915 Views)
I has Problem PC-TIO-10 but you send this example for DAQ EVENT 8 works with the following devices: for me
- Lab and 1200 Series devices, except the SCXI-1200 with remote SCXI
- DIO-653x devices, DIO-24 (6503), DIO-96 (6508), PCI-6025E, and AT-MIO-16DE-10
I still can not solve problem.
(3,915 Views)
