Counter/Timer
low side driver
I am trying to create a signal to connect to a module that requires an open/collector drain low side driver with low frequency pulse at 50% duty...< 200 Hz.  I am working with a 6624 and can create the signal from the board with a resistive load on Vdd and out.  Unfortunelty, when I hook up to the module, the module does not work.  On the other hand, I can succesfully use an agilent waveform generator with the same ouput chareacteristics and wire to the same pins of the module and gain success (Success is a functioning ouput of the mdoule).  The only thing I can conclude to is that the module requires a high side switch or sourcing event.  Because I have limited equipment available at this time, I have tried only to create the high side switch by using a counter output of a 6221 to drive a solide state relay that switches the high side...again the signal with the desired frequency is produced but the module does not function.  I know I have offered only limitied info about the module so answering may be difficult but I was hoping someone may have some similar experiemce or comments to add.  I know little about the internal schematic of the module and will probably not be able to get this info.
thanks in advance.
(5,063 Views)
Hey
You can use external NOT gate.
Good luck
Lab
(5,030 Views)
