Counter/Timer
low velocity measurement using 6601
I am using 6601 on measurement of position and velocity of increamental encoder. Our sevor motor rotate at very low speed. How can I measure the velocity at high accuracy at the same time of measuring the posstion of encoder.Can you provide me some tip? Thanks.
(3,476 Views)
Hello;
You can use two counters to accomplish that task.
The first counter can be used and configured as position measurement. That will make the counter to give back the position of the motor.
The second counter can be used as buffered event counter. You just need to route one of the encoder channels to the counter gate, and since you know the frequency of the source, and at every event of a gate pulse, the internal value of the counter is transfered to the buffer, you can do a quick calculation with the number retrieved and the source signal frequency.
Hope this helps.
Filipe A.
(3,476 Views)
