Counter/Timer
max nuber of PWM outputs NI USB-6221
I'm using the NI USB-6221 which has two counter to my knowledge. I need to output 6 PWM signals (same freuquency, but independent duty cycle) to control 6 external valves. Is that somehow possible or would I need a DAQ device with 6 counters?
Best thanks for any help/idea!
(2,852 Views)
Accepted by topic author maxJack
Assuming you need to vary the duty cycle as the program runs, you'll need 6 counters.  In addition to the 2 you have on your USB-6221, you could add 4 more with an X-series board (which are available in USB form, unlike the dedicated counter/timer boards).
-Kevin P
(2,824 Views)
Hi Kevin,
Thanks for your reply. You correctly assume that I need to vary the duty cycles during run time. I will consider your suggestion.
Best,
maxJack
(2,814 Views)
