Hello;
The maximum frequency that the source input of the counter can have a signal hooked up to is 8 MHz.
To measure a 1MHz signal, just connect that signal to the source pin of the counter, and use one of the examples that both NI-DAQ and Labview have to start your application.
Hope this helps.
Filipe A.
Applications Engineer
Naional Instruments
