Counter/Timer
measure a 20Hz TTL signal frequently
I need to calculate the frequency of a TTL signal (0 to 100Hz) very often, in order to record it. I'm looking for a way to obtain this frequency as often as possible, with a 2 digit precision. I've not find out how to do from the NI examples.
Any idea will be welcome.
Thanks.
(3,338 Views)
Hi C.R.,
You can use any example program that uses buffered period measurement with 1 counter. What happens is that every time your TTL signal goes through 1 period, that value is latched into the buffer. If you have a small buffer, your program will be reading this buffer in quite often. You can then take the inverse of the period measurements to get the frequecy. The advantage of using a buffered period measurement with a counter is that it is continuously getting the instantaneous frequency of each period. By latching into the buffer, you can take an average of the buffer to get a more normalized value. Check the shipping examples of your software package for these examples or go to ni.com/support and click on Example Code link to search for examp
les. Anyway, hope that helps.
Ron
(3,338 Views)
