Counter/Timer
nisync API in cRIO
I am using a cRIO 9049 with 1588 synchronization. I need to use the NISYNC API using a C++ application. Where I can find examples or the latest information on NISYNC API?
(2,407 Views)
Some of the examples are only provided for CVI and unfortunately, the examples for NI-Sync (attached) are not updated for time-based synchronization. Perhaps your best reference would be the shipping examples from LabVIEW.
Monitor and Configure Time Synchronization on Embedded Devices
Using NI-TimeSync to Configure IEEE 1588 and 802.1AS Time References
I don't have access to any hardware with NI-Sync support currently. Otherwise, I might be able to "convert" and validate the C examples from LabVIEW.
https://tmesystems.net/
(2,384 Views)
Thanks for your message. I was following exactly that approach but I was trying to see if there any other detailed example for cRIO-904x famili using the 1588 synchonization.
(2,379 Views)
