I discovered that it also seems impossible to connect the counter to an external clock signal on a PFI terminal.
Alternatively I tried writing a digital pattern out, but this also doesn't work because the external clock on a PFI terminal cannot be used.
In both cases I get a: "DAQmx Base Error: Specified property is not supported by the device or is not applicable to the task.".
The behaviour can be reproduced by running the example "ContWriteDigPort-ExtClk" example in "/usr/local/natinst/nidaqmxbase/examples".
I'm getting the same error when I try to use an external trigger on a PFI terminal. It is a bit of a problem, as I would like to generate a finite pulse train, using an external clock, starting on an external trigger...
Martijn
