01-14-2011 04:37 AM
Hello!
I am using NI PCI -6251 and SCB-68 E SERIES DEVICES and LabVIEW 8.6.1 and have got incremental encoder which have A, B , Z signals.
I want to measure speed with DAQ. I used DAQ assistant (counter for measuring angular position) with 3 inputs
A signal (PFI 8)=37
B signal (PFI 10)=45
Z signal (PFI 9)=3
From DAQ assistant I get angle in radians or degrees or ticks.
I want to know how if DAQ assistant have some setting or .vi to measure speed with.
Or which will be the best way of measuring speed in Labview.
I also want to know how to get settings from DAQ assistant from the block in indicator.
Thank you for your answers.
01-17-2011
01:48 AM
- last edited on
09-06-2025
03:45 PM
by
Content Cleaner
Hi DODI,
If you are looking for the best ways to implement some operation with your M Series DAQ, then I would suggest M Series User Manual. On page 7-6 (112 in pdf) you can find for example one possible use of counter input - period measurement. In fact it is what you need to do - because to measure speed, you need to know the time between 2 pulses, or by other words you need to know how many pulses of known timebase occure. You also need to know the distance obviously - which shold be simple, as when you use incremental encoder, then you know how many pulses you get per 360deg (which means you know how many deg you have between 2 following pulses).
This means, that you can get speed by dividing distance (known from your encoder) with time (known timebase frequency * number of pulses).
I hope you didn't get lost ![]()
Unfortunately I don't understand the last question of yours: "I also want to know how to get settings from DAQ assistant from the block in indicator." Could you maybe clarify what you need here?
regards,
Stefo
