Counter/Timer
synchronizing counters output using NI9401
I'm using cDAQ9174 and NI9401; I need to generate two synchronized square waves (using two counters). The two waves could have different frequencies (from 500Hz to 7KHz) and duty cycles, but I need they start at the same time (first rising edge together). Is there a way to synchronize the two tasks? I would prefer without using an external trigger.
Thank you in advance for the answers
(5,804 Views)
Hello Domcar,
 I think the best way to synchronize your two counter outputs would be to use a dummy task as shown in the following link. Could you please take a look?
Synchronize Two Counter Output Tasks Using a Dummy AI Task
https://forums.ni.com/t5/Example-Code/Synchronize-Two-Counter-Output-Tasks-Using-LabVIEW-with-DAQmx/...
Antonios
(5,800 Views)
