Counter/Timer
using USB 6341 device for frequency generation but level is droped when conect
Hey Nasib,
It looks like you are generating your frequency correctly. Because your voltage is dropping by such a relatively large value, it looks like you could be greatly overloading the 6341. The minimum resistance that you can connect to that card is 313Ω (5V/16mA).
Travis Ann
Customer Education Product Marketing Manager
Message 11 of 15
(3,660 Views)
thanks,, but wat can i do to to minmize the drope.
Regards
Naseeb
Message 12 of 15
(3,658 Views)
Accepted by Nasib
Hi Nasib,
You need to try to match the resistance to be at least 313Ω, so that you don't overload the card.
Travis Ann
Message 13 of 15
(3,651 Views)
Helloo..
Can you tel me how to generate the a frequency of 10KHz of freq. Sorry I m new to this labview.
Thankyou
Ashwin
Message 14 of 15
(3,594 Views)
Hi ash.gn2011
You can open a LabVIEW example to generate the 10 kHz.
Follow this example, configure the sampling rate to 100kHz and adjust the frequency to 10kHz.
These articles explain more about DAQmx VIs and analog sampling.
Also please remember to create a new post for every new question since this thread was closed almost a year ago so we can keep a better track of the forum.
Regards
Chris S.
Message 15 of 15
(3,582 Views)
