Counter/Timer
using pci6602 with simulink
hello..
> i have some problem with simulink.for your information,i'm using the
> latest version of matlab R2008a.
> i'm using the digital input and digital output in data acquisition
> toolbox.i'm using the data acquisiton card from national instrument
> that is PCI6602.but i have some problem when i want to run it.the
> error appeared "data types at the input port must be logical type".i
> have upload the block diagram of my project
> the configuration parameters i not change it.
> ok,thank you
(4,377 Views)
Hi keluangman,
The digital output requires a logical data type and you have currently wired a sine wave to it according to your block diagram. You should try wiring a boolean data type as an input.
Steve B
(4,347 Views)
thank you. but can you give a suggestion to replace the sine wave with the boolean data type.what kind of boolean data type that i should use?
(4,341 Views)
Hello keluangman,
The PCI-6602 is a counter/timer board that can be used to input and output digital signals.  This device responds and outputs TTL specified signals.  As a result, to output a digital signal on any of the digital output lines (like port 0 line 0; P0.0 for instance) you need a data type that represents this line.  For a single line you would need a Boolean data type (represented as a TRUE or FALSE; sometimes a ‘0’ or ‘1’).  If you had multiple lines associated with a single output option, you would need an array of Booleans (one element in the array for each line on the device) or a integer in which each bit on the integer represented a line on the device.
Browning G
FlexRIO R&D
(4,319 Views)
thank you for your help...:)
(4,311 Views)
