Counter/Timer
what is the pin no for the NI X6221 counter
i am the new guy just started my labview learning, i want to connect a encoder with 5 lines to the NI X6221 board, i have read some of the question posted. i have read the manual also, but the munual just mention that there are 2 pins on this board which can be used as a counter. but i just do not know which 2 can bu used? what's pin no. and how to read  PCI/PXI-6221 (68-Pin) Pinout diagram. which pin no should i used to connect the encoder from the NI 622x Specifications page 14.
(4,695 Views)
Use DAQ Assistant to configure counter channel.
It'll tell you which PFI line connect to which signal.
Then, go to Start>>All Programs>>National Instruments>>NI-DAQ>>NI-DAQmx Help.
Search 6221, and see which pins belong to which PFI line.
(4,680 Views)
