DAQExpress
DAQmx Error Code = -2147220721
I'm trying to start a piece of software called CTS 4 (California Instruments) and when I try to start the program I run into this message:
"DAQmx Error Code = -2147220721 Error Message = MAX; (Hex 0x8004030F) The configuration database cannot be opened, possibly due to corruption. Please note the steps you performed that led to this error and contact technical support at http://ni.com/support."
Any help on this would be greatly appreciated.
(5,588 Views)
NGrade,
Most likely the error is caused by a corruption in the MAX database. To fix this, you will need to reset the MAX database file. Here is a link that can show you how to do this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC
If this does not work, please reply and we'll go on from there.
(5,542 Views)
