DAQExpress
Use DAQmx drivers with Analog Discovery 2
Can I use DAQmx drivers with Analog Discovery 2?
(4,008 Views)
The short answer is no.
The Analog Discovery has its own driver that is documented here:
https://forums.ni.com/t5/Analog-Discovery-Student/Getting-Started-with-LabVIEW-and-Analog-Discovery-...
If using DAQmx is a must you could have a look at the myDAQ, which is in a similar price range but not the exact same functionality.
Cheers,
Anton
(3,790 Views)
