DAQExpress
Regarding combining input and output task
Hello Everyone,
I ma new to the NI environment and I was trying to read a signal from an input task in DAQExpress and then based on the input signal generate an output signal. However I am not able to combine both the components. I am able to generate output and read input separately.
Is it even possible with DAQExpress or do I have to move to LabView
Thanks in advance.
Chinmay S
(3,368 Views)
This may be a good place to get started:
http://www.ni.com/en-us/innovations/white-papers/18/counters-and-triggers-using-daqexpress.html
(3,347 Views)
