DAQExpress
pressure channels
on DAQ assistant (express) if i choose analog input and then pressure (pressure bridge) , then no channel appears there. My professor says that maybe missing a add-in or a license. Sorry for my english and thank you in advance
(3,774 Views)
Hi Stam21,
Check out the link below for an introduction to using DAQExpress:
Programming Using DAQExpress
https://www.ni.com/docs/en-US/bundle/daqexpress/page/lvex-gs.html
Could you provide screenshots of the issue? Also, is there a dialog box or pop up that suggests that something like a license is missing?
Jiwhan S.
Technical Support Engineer
(3,744 Views)
Hello again,
as you see in the photo, when i choose pressure (pressure bridge) no channels appear. I tried with voltage and it appears normally the channels.The same happens when im trying to connect an optical encoder and on angular no channels apear again.
Thank you.
(3,738 Views)
Hi stam21,
This indicates that your hardware does not have a channel that can take that pressure measurement. You'll have to have hardware that supports this measurement. See the link below:
Strain, Pressure, and Force
https://www.ni.com/en-us/shop/category/strain-pressure-and-force.html
Jiwhan S.
(3,724 Views)
